ASUS TUF 7900 xtx running very hot
1 Nov 2012
lancatser
ASUS TUF 7900 xtx running very hot hot spot is 110 after about 5 min of use and shuts down some time aswell
ASUS TUF B650-plus
AMD Ryzen 7600x
32GB 6000MHZ ram
ASUS TUF 7900 xtx
How old is it? Recently repasted my 6900xt that had a hotspot of 114c. Used MX6 paste and now hotspot is 70c max.
Yea it vertical cables up but at most it would be 2-3c still should not be getting 110c
Run a benchmark with the adrenaline overlay and see if the temp hits 90+ almost straight away. It will also probably not be able to hold a steady high load and fluctuate all over the place. Either repaste or RMA if able.
That case puts the GPU in an unusual orientation doesn't it? Though, I think the TUF uses heat pipes rather than a vapor chamber.
TUF XTX uses heat pipes, link.
i ring overclockers in the morning i should be able to rma it it only 3 months old
As it's only 3 months old unlikely to be "pump out" of TIM, RMA it.
