Asus Xonar DX Problems..
3 Oct 2013
Hi,
I've just purchased a ASUS Xonar DX and I've installed it into my PC and plugged in my speakers, I installed the drivers and now when i try opening the xonar audio center an error comes up saying 'can't find any device'. There's no sound coming through whatsoever. I'm running Windows 7 64bit.
The card shows up in the device manager with a small error sign next to it.
I'm using the unified drivers.
Any advice?
Have you tried the latest Asus drivers, it's usually best to start with them before playing with the unified ones.
I've tried the drivers from the Asus website gives the same error. I've powered the card with a floppy connector from my power supply and I've installed the card into a PCIE x16 slot.
I've tried the card on windows 8 with the unified drivers and it worked straight away after installing the drivers without any problems.
Any idea why its not working on windows 7?
