Asus Z87-A does not see Crucial MX500 1TB SSD
17 Sep 2024
UK
Hi, I hope someone here can help. I searched everywhere but I haven't found a solution to my problem. I have Asus Z87-A with Bios 2103 which I think is the latest version available.
I bought Crucial MX500 1TB SSD to install system on it but I cannot get Bios to see the SSD. When I go to SATA Information it show the SATA slot as empty. The drive is connected using Sata power cable and Sata data cable (no Molex involved). Everything boots up without any issues, warnings when SSD is connected but it is not visible in Bios.
I tried setting SATA config in Bios to IDE, AHCI, switch off Fast Boot etc. Does not help. I have honestly no idea how to get the Bios to see it. I have been searching for a solution for a few days. I also changed the cables just to make eliminate this as a root cause. I also tried different SATA ports in the mainboard.
Is the SSD new or 2nd hand?
Do you have an external caddy or something similar you could test it in via USB instead?
If you use it as a 2nd drive and boot in to Windows can you see it via disk management?
Looking at the Asus site 2301 is the latest bios for the board.
The SSD is brand new. I will try to see if I can connect it via USB.
Meanwhile, this is the latest BIOS I am getting on Asus website:
Z87-A BIOS 2103 and BIOS updater
Version 2103
12.37 MB
2014/09/12
Also, I have found a list of supported devices on Asus website. Does anyone know if I am restricted to only purchasing one of the models on this list? Most of them are 120GB or 240GB.
No, not showing in Bios under Sata or Boot config, not showing in Windows in Disk Management, not showing in Windows in Device Manager under drives or anywhere else
Do you have a friends computer or another computer to try the drive in ?
Just to add, if I move drives around and plug the HDD's into different Sata ports in the mainboard it detects them correctly in new ports. SSD not detected at all. I wondered if there was anything in Bios that was not enabled for SSD support? Couldn't find anything
if bios doesn't detect the drive then windows won't either
what other drives are connected to your sata ports?
if you bought the drive used then my first guess is that the drive is dead already and you got scammed
use the sata cable AND the power connector of a known working drive, connect it to your new MX500 and see if the computer will detect it
that way you know that it is not the sata port, not the sata cable and not the power connector
if those don't work then the only options are (a) incompatible drive, but i've never heard of this before...or (b) dead drive which is more likely
As I said already, the drive is brand new. Other drives connected to Sata ports are HDD drives and a DVD player
