Good luck, and let us know how you get on![]()
Will do
I've got big hopes as at stock it's 26-32c idle and load is 48-54 in IBT.... This Phanteks beast is pretty darn good.
Congrats, that's a very nice voltage for 4.5, better chip than mine.
I thought I read somewhere that changing BCLK was very very bad for SB-E and never to do it? When I tried the AI Tune thing on the Asus, I was appalled to see it push BCLK up beyond 106. Soon put a stop to that![]()
BCLK tuning is fine on SB-e but very very bad on SB
On X79 the important clocks are fixed, on p67/z68 they are not, so you have to stay close to 100.
125 BCLK is used a lot by 2011 owners,
I would say by all those with 3820 CPU's.
Turns out Boinc/Rosetta is a better stability test than IBT and Prime95. Where those run ok and show no errors, Boinc will give me BSOD.
Currently on 1.28V. Hopefully won't need to go higher than that![]()
Cool (or hot rather)
What cooler are you using by the way?
Mine seems to be coping now with 1.28 under load, but one of my cores peaked at 80C
Really am pushing the limits here. Interesting to see how it copes in warmer weather.
Am going to try a Armageddon next week, not because it is any better at cooling but beacuse it will fit in my setup and clear the ram.
Will post back with results
