- 18 Jul 2021
- Land of Gin (I wish)
My previous car the gearbox failed. £850 I was quoted. Wasn’t going to spend that money on a car worth £2k.
Not sure what's up with him.
Actually, the statement "The 'steak analogy' is also faulty, a car part is not a steak" is probably more deserving of the laughing emoji, since the whole point of an analogy is that it's a comparison between two different things in order to clarify, explain or give an example.
You know, like a car part and a steak.
He's always had some issues with caring too much how people perceive him, it's why pretty much every single one of his posts is edited
and why he changed his name.
if you fit parts to a car that you haven't bought or aren't responsible for and they fail, it's you on the hook, not the parts supplier.
Doesn't matter if it is top of the line stuff in a sealed box, the facts are that there are fake manufacturers, copies, and even if the part is genuine, who's to say it's not a manufacturing reject or doesn't have a fault?
All fun and games flying the flag of "I won't do business with a mechanic that won't fit parts for me that I've supplied" until one day a wishbone snaps and ploughs you in to a hedge, who's to blame then? Good luck unpicking that mess.
I dread to say it but any mechanic who agrees to fit parts from a customer is probably a bit dim or hasn't been burned yet.
If the part physically breaks, it is the component manufacturers fault.
You just called the majority of all mechanics a bit dim, including some of them in this thread.![]()
True.
And what do you think the manufacturer is going to tell you if you try and take it up with them?
I didn't want to go in to the details, you discussed it a few years ago and I totally understand the situation. Hope it's going well btw![]()
I guess it depends? But if a wishbone physically breaks and results in someone's death, the company under scrutiny would be the manufacturer not the garage that fitted the part.
If the bolts backed out and it fell off, well, thats different.![]()
Really, any evidence to back that up?but I'm sure in a lot of cases they will just go for the cheapest one available and then mark it up to maximise profits.
The fact that most people are money motivated.
Some 'trash' parts aren't likely to fail in a timeframe that would cause the garage any issues.
I had to lol at that.Some 'trash' parts aren't likely to fail in a timeframe that would cause the garage any issues.
Do you have any experience of warranty claims?, or parts failure and the costs involved?
That was rhetorical btw, cleaery you don;t.
Do carry on though, its worth a laugh
Depends where you go main dealers will use genuine parts and have mechanics trained to the job but you'll pay for the privilegeWell what brand of wheel bearings do you usually fit when a customer doesn't specify? Or brake disks and pads? Dampers? Timing belt kits? Ball joints?
Perhaps I should be more trusting, but its in my nature to be sceptical unfortunately...
Am I completely wide of the mark? Do garages tend to fit quality parts and have these policies to stop customers from supplying cheap ones?
Am I a weird fringe case who does it for the opposite reason? Is the reason why I have never had any issues because I always plonk down boxes stamped genuine, or Bosch, SKF, Bremi, Bilstein, Denso, etc?
Thats cheap I was quoted that just for the clutch!My previous car the gearbox failed. £850 I was quoted. Wasn’t going to spend that money on a car worth £2k.
