Bugger ! Just unplugged the old "LOUD" fans from the Antec P180 case and discovered that the stock AMD fan on the CPU heatsink is quite noisey as well. Seeing as I'm replacing the Northbridge fan and all the case fans I may as well do this one as well ... what is the best solution for a heatsink and fan that will fit straight on to the CPU?
So these will just clip straight on I assume? I don't want to remove the mobo or anything just replace the thermal paste and clip straight on. Also are all the power supplies/plugs the same? I have a Asus AN8-sli deluxe mobo
