ATI card and NV for physx in one system
the 8800gt that the shop have in stock
An 8800GT would probably be fine for Batman AA, but the recommended requirements for mafia 2 are significantly higher if you want to turn PhysX up to the max.
Mafia 2 Video Cards and resolution: APEX High settings
Minimum: NVIDIA GeForce GTX 470 (or better) and a dedicated NVIDIA 9800GTX (or better) for PhysX
Recommended: NVIDIA GeForce GTX 480 for Graphics and a dedicated NVIDIA GTX 285 (or better) for PhysX
Damn, I was thinking £60 for PhysX was expensive :S
Now I gotta fork out for at least a GTX260 to get even remotely enjoyable experiences :/
Man PC is expensive
Didn't nVidia do some drivers recently where they "accidentally" allowed PhysX with any other main GPU, even an ATI one?
i remember reading a while back that the lowest u want to go for physx is 9800GT, anything less and it actually slows u down.
the 9800 is jsut a rebadge 8800 anyways, so it should be fine.
i wouldn't go any lower than that thou
ok random thought
can you sli 2 nvidia cards as physx cards ?
im not planning to, just crossed my mind
i doubt it, SLI doesn't work like that.
essentially with SLI, each card renders half the screen and then joined together.
as physx is just processing and not rendering, it wont work the same way.
im not enterly certain, but i dont think it would work.
I believe the Nvidia drivers Tute refers to are the 257.15 drivers. They were available for XP and Vista/Win 7 (got 'em stashed on my hdd safely for when I get a 3 pci-e slot mobo) but I don't know if they are still available.
