david.n.c said:yep agp, budget £100, will sell 9600 so dont know what i'll get for that.
Zefan said:EVER.
Yes it's worth two posts
6800gt off ebay or a x800xl should do you good.
To be fair, 512MB RAM does jack for cards that slow. It barely does anything for even the newest cards, to be honest. If anyone were to buy a GTO I would definitely recommend the 256MB model instead and have them save a few quid, just me though.SteveOBHave said:ust over £100 (£105.69 Including VAT at 17.5%) will get you a Sapphire ATI Radeon X800 GTO 512MB DDR3 TV-Out/DVI (PCI-Express) - Retail (GX-118-SP) from OcUK which will give you a fair amount of future proofing...
SteveOBHave said:The performance difference and the application of the hardware is going to make little difference and there are pros and cons for both brands. Either way you should be happy with the outcome.
Try Googleing and read a few 'shootouts', read the reviews of people that have bought them, look for the cheapest price and a deal that happens to be going at the time...
Just over £100 (£105.69 Including VAT at 17.5%) will get you a Sapphire ATI Radeon X800 GTO 512MB DDR3 TV-Out/DVI (PCI-Express) - Retail (GX-118-SP) from OcUK which will give you a fair amount of future proofing...
Just under £100 (£99.82 Including VAT at 17.5%) will get you a BFG GeForce 7600 GS OC 256MB GDDR3 TV-Out/DVI (PCI-Express) - Retail (GX-024-BG)
also from OcUK which gives you the legendary BFG lifetime warranty.
Streatching just a little further to (£135.07 Including VAT at 17.5%) will get you XFX GeForce 7600 GT 256MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail (PVT73G-UDL3) (GX-078-XF) which is also a brilliant little card.
Point is, if you look you will find, the info is there and for future reference a thread header should try to be accurate rather than incite a flame war![]()
