- 28 May 2007
I think saphire have changed there coolers also on there stock cards according to a topic around 2 weeks ago. The pictures on ocuk are not always up to date i think.
The 260-216 has a lower idle wattage. Depends if you use the computer a lot on the desktop.
Physics on the Nvidia card wins over dx 10.1...look at Cryostasis for example with the diff. in frame rates.
Can overclock the 216s to 280 stock performance.
imo the Control Panel of Nvidia's is better than the ati's equivalent.
You tend to get a longer warranty with nvidia cards.
I did read that there were probs with the 4870s too with a higher failure rate and driver issues.. might be fixed now though.
Is this new Sapphire cooler guaranteed to be on all their 4870 cards?
well.....i have a 4870 512 mem card....running on a p45 chipset....am looking at getting a 280gtx...or another 4870 for crossfire....which would be the best option...1x gtx at 16x pciex or 2x4870 at 2x8 lanes pciex...any help much appreciated
Ignore this review as it only uses 180.47 drivers. The since released "Big Bang 2"
drivers 180.48+ have significant performance gains over the 48xx cards.
FixedThe since released "Big Bang 2"
drivers 180.48+ have significant performance gains over the 48xx cards using 8.11.
hope 8-13 are good
they are dead mate again, the 1gb performces about the same as a 216 core GTX260 with the 8-12 drivers and its a more powerfull card to bad ATI can't build drivers properly or that wouldn't happen. but both are cracking cards, it depnds what you do with it looking a bit tech and yeah even my HD4870 512 can beat the gtx260:O but than 8-12 drivers are betterhope 8-13 are good
Ahh I see, sorry. At the moment I don't have any links, I'm on my iPhone at the moment so I can't copy and pastebut you should be able to find some on techpowerup of the older drivers.
