ATIKMDAG.SYS
Caporegime
18 Oct 2002
Ireland
Got this earlier while playing MW2 sp, game locked up and bluescreened, since then ive not been able to get the 3870x2 to work again, just keep getting a constant bsod loop when trying to load windows.
Ive cleaned out the drivers in safe mode using an older 8500gt, ive tried different driver revisions, ive tried installing win 7 on a different hard drive, issue still exists but after it bsod'ing once it boots up under a generic driver and tells me its disabled the ati card, if i reenable it same situation. :confused:
Any suggestions? Ive really no clue what to try.
Can you try the card in another PC?
Nope, brothers case won't accomodate the card =/
Sounds like something died :(
Im guessing so as well, a while back the card wouldn't work at all, i tok it apart and reasembled then it kicked in again. The fact that across 2 totally different drives its throwing up the same problem makes me think some part of it has croaked as well.
