Atom System Problems
I'm getting my replacement system tomorrow myself. I returned the Atom 230 based Jetway barebone, and I get the newer, better board with the same Atom but Gigabit Ethernet etc.. also picked a slightly bigger chassis.
You can find 2GB Hynix DDR2 for well under £20 too, if you look around :D
Thats the problem I've been having... I'm building a Atom 330 in silverstone LC05 with 500GB hdd, and 2GB ram, but I've got a budget of £200 and the rest I get to keep, so I want cheap but reliable memory so I don't have to replace it... WTF is DDR667 single 2GB sticks so damn expensive, You could by 2x2GB DDR800 for much less than 2x, but I can't use one, cuz if separate the warranty is void....
Damn inflation...
You can put any speed DDR2 as long as it's greater or 400. The stick I have in is 800 and it just settles back to the highest speed supported (533). A bit of a waste, but yes, the 800 is now cheaper than the 400 & 533 in most cases !
um, paper is made out of wood. and trees are conductive - hence when lightening likes striking them... wouldn't that defeat the whole point :confused:
Dead trees have no conductive capacity but living ones do have some slight conductive capacity owing to the water in the leaves/trunk.
