I know it isn't PSU related but it is related to electrics so maybe somebody who knows could help me
I want to keep this aftermarket cooler but it has an issue with the fans constantly revving up and down when idle.
My older stock cooler would turn off if I set the fan curve to 0 but it won't work with this new cooler.
I want this cooler to do the same but it won't so I was wondering if it is safe to add simple on/off switch to GPU fans.
You can switch case fans off with switches but the difference with my intended set up would be the fact that the fans would be connected to the gpu board so I am just wondering weather it would bust the GPU, I am not sure how seeing as the GPU obviously has a voltage regulator where you can turn it up and down at high speed anyway.
I was thinking of ordering a mini gpu extension cable, cutting the voltage wire and inserting them into a simple switch that I could turn off when not playing games.
