- 8 Oct 2008
- Hull, East Yorkshire
Here is a profile for you to enjoy gaming with the same ergonomics as a right hander if not better. No more having to slide your keyboard to the far right and awkwardly using wasd.
p - walk forward
l - strafe left
; - back pedal
' - strafe right
That's your basic WASD colony. Next is reloading etc.
i - reload
o - use
[ - quickswitch
k - flashlight
That's general FPS games like half life.
Now the interesting advantage for lefties. You have a big enter key and a shift key plus a # key to use with your pinky. You could set enter to crouch which works very well because your hand lays flat naturally. Unlike a right hander who has to stretch their pinky to the ctrl or use their thumb to press c.
So in say CS:S you can crouch jump with Enter and Space very nicely. Or you could map enter to run in cod or use # to run which leaves your hand resting without even having to move.
I use AltGr as walk in css and enter as crouch, works really well. You can use # as tab for scores or enter as inventory for RPGs.
It's better than using the numpad it's too sqaure and nothing beats spacebar for jump.
So yeah this is better than a right handed setup imo. I know right handers can remap too but generally it's perfect as it is that's why it's default in most games.
p - walk forward
l - strafe left
; - back pedal
' - strafe right
i - reload
o - use
[ - quickswitch
k - flashlight
