You know I haven't actually listened to my DT990's for a while, but I just hooked them back up to my Fiio K3 amp/DAC on my PC and did some switching back and forth with the Maxwell.Deffo agree they are much sturdier with more metal in the headband.
Because I'd looked after mine and they failed later due to the fact, Audeze will only offer me a B grade replacement for the Mobius that I have toi ship the old set and pay for the import of another set, that will, ultimately fail in the end.
Wish I'd treated them more roughly so they failed earlier.
Here I am moaning and I still bought another set from Audeze.
@TallPaul_S I see you have DT990's in your sig which are a decent set (I've never heard them), how you compare the DT990's to the MAxwell's?
Anyone compare these with the Mobius?
Are the WC FreeZe pads deeper? I have similar issue where ears touch and can hurt a bit after a few hours.Just bought these. I found them uncomfortable with the stock pads, my left ear kept touching the driver. Ears got hot pretty quickly too. bought the WC FreeZe ear pads and feel much better. Surprisingly the headset sound great with music.
Yes they are. My ears no longer touch the drivers. They make them tighter around your head so the clamping tension is stronger. Ears don’t get as sweaty as well. I recommend getting them.Are the WC FreeZe pads deeper? I have similar issue where ears touch and can hurt a bit after a few hours.
