Driving along the motorway and the oil sensor kicked in,ended up drifting the to the hard shoulder, checked the oil once the car had cooled down and there was sufficient in inspected the bottom of the car definatly no sign of any leak.
Managed to limp home with some horrible grating sound coming from the rear of the car and put ome Oil in even though I know there was sufficent in it, left overnight and checked this morning.
However as soon as the rev go over 2k the Oil sensor kicks in and back to square one. So has anyone got any ideas of how much this is likely to cost me to fix? Biggest problem I have is that I need the car to get to and from work, unless I want to spend the best part of over 2 hrs on various buses to and from work.
