It doesn't work the same for different system / different listeners.
If you can't hear background noise then it wouldn't do you much good, IMO most people don't really need one.
Seems a bit overkill to me - especially when they are suggesting additionally filtering other local devices. A lot of digital ICs, etc. won't really be effected by it and largely a simple 100nf ceramic capacitor will do most of the same thing and if you wanted a bit of ground loop elimination, etc. its possible to build something a lot cheaper than those cost.
Possibly a ground loop between the speakers and the X7 then, rather than PC to the X7. If the noise were coming from the PC, then you'd surely hear that with headphones as well as speakers.
The jitterbug would likely make no difference if the noise is not coming from the PC.
Try a ground loop isolator between the RCA cables from X7 to the speakers.
I bought my friend a Jitterbug for his digital music system (which is pretty high end) last year. Difference in transparency of sound is very noticeable.
Interesting.
Yup. We both noticed it within seconds so the jitterbug is not snake oil, that's for sure.
We're talking about $2500 worth of equipment he's got though so I wouldn't buy the jitterbug for your average low end studio monitor+ low end DAC setup, for example.
There is also a product called an UpTone Audio USB Regen, which the audiophiles are all quite crazy about, to a much greater extent than the jitterbug. It's more expensive though.
