Thank you for your email.
I can confirm that provided you have a full category B licence (limited to automatics only) you will
be entitled to drive a vehicle meeting the below criteria.
A vehicle with automatic transmission means a class of vehicle in which either:-
the driver is not provided with any means whereby he may vary the gear ratio between the engine
and the road wheels independently of the accelerator and the brakes or:
he is provided with such means but they do not include a clutch pedal or lever which he may
operate manually and accordingly, a vehicle with manual transmission is any other class of vehicle.
Most vehicles fitted with automatic transmission today have a “hold” facility whereby the driver can
select a lower gear ratio “manually” for descending long steep gradients rather than relying totally
on the brakes.
This facility is sometimes used for increased power when overtaking slower vehicles rather than
using “kick down” on the accelerator, but we do not believe that this constitutes manual
transmission.
Regards
Mr I Owen
www.direct.gov.uk/motoring
http://www.pistonheads.com/gassing/topic.asp?h=0&t=625270
