- 19 Oct 2002
- Shakespeare’s County
Oh god please stop. Even I’ve timed out on this one.
Does line lock(with servo?) apply same force as handbrake ... and would withstand someone bumping you from behind.Auto hold doesn't use the handbrake, it's a line lock on the hydraulic brakes.
On today's episode of 'Extremely Pedantic Arguments on the Internet'![]()
yes - it's hot air on an oiriginally useful thread -
How is zf/asin going to diversify when auto-boxes are no longer needed by ev's (although lorries maybe not )
If any of these asertions were true, like how heat does rise, how a vacuum cleaner does create an actual vacuum, etc, you'd have already posted links to prove it... and we'd not need fans on our W/C radiators.And to think, he accused others of being obtuse earlier.
And yet nothing on this forum is considered true or valid without links, citations and references to studies and articles...Imagine having to resort to 'links', one way to prove you don't really understand the subject...
The pressure level in the area behind the fan drops below the pressure level outside the vacuum cleaner (the ambient air pressure). This creates suction, a partial vacuum, inside the vacuum cleaner.If any of these asertions were true, like how heat does rise, how a vacuum cleaner does create an actual vacuum, etc, you'd have already posted links to prove it... and we'd not need fans on our W/C radiators.
Note the 'partial' and the reason for the inclusion of that word, to differentiate it from an actual vacuum. The latter would be a complete absence of matter, which would then beg the question what you've just vacuumed up if there's no matter.The pressure level in the area behind the fan drops below the pressure level outside the vacuum cleaner (the ambient air pressure). This creates suction, a partial vacuum, inside the vacuum cleaner.
That was merely a difference of opinion, whereas this is about established definitions and other peoples' interpretations of them to suit their perspectives.It is nice to see you hadn't just singled me out when you posted a load of drivel on the meal kit thread![]()
I take it this thread has gone off topic.....
Back on topic then - manuals are still better.
Presumably the Mini had a boot full of bricks?
Your Navara does 120mph?
