Autoglym High Definition Wax
Looks good. I'd be interested to hear your thoughts on it when you get a chance to use it. I currently use Meguiars NXT but it doesn't seem to be any better than the "normal" waxes out there.
Yep tried it the other week, very impressed. Work sells it and I get 20% discount :D
I've only got crappy phone pictures but you get the idea...
Not too bad for a 7 year old ford :)
I got a tub of this for displaying my car at the PH show, didn't realize it was £30 a tub!
The packaging was very good, the wax itself im not to sure about, it did very very well, but then, I haven't had a chance to try it out properly yet with a polish etc etc.
Wash
Polish
Wax is the way to go yes?
If you want a decent polish, then dont look any further than the Autoglym super resin, it as fillers and a mild cut, so it can fill some minor swirls, and 'clean' the paint at the same time.
Dont bother with the Megs Paint cleanser, its not very good, tbh much of the megs retail stuff is over priced and not very good.
I cant reccomend the Collinite 915 highly enough, it just lasts so bloody long, and the finish is top class, victoria and poorboys,natty's blue,petes are all excellent choices (better finish than Collinite, but done last as long) and cheaper than the AG one posted above.
I'm no expert but basically I think it works like this..
washing - removes surface dirt etc
claying - removes bonded contaminates, tar etc
paint cleaner - removes light oxidation, swirls, scratches
polish - gives the high gloss finish and conditions / nourishes
wax - gives the final finish, seals it all in and protects..
Not in my experience:(
Theres just so much stuff out there now to try.
Im using the sonus sfx stuff at the mo.
Hated the sonus stuff, used it twice and never again!
Current list of polish/wax is...
Auto Glym Super Resin Polish
Auto Glym Extra Gloss Protection
Meguiars NXT Wax
Meguiars Cleaner Wax
Collinite 476s
Looking to get the AG HD Wax next, and something like Dodo, not decided yet?! :confused:
