Auzentech X-Fi Prelude 7.1 Sound Card : Driver issues
18 Oct 2002
Cambridge, UK
Hi,
I'm outputting over SPDIF (Dolby Digital Live) and using X-Fi CMSS-3D (Stero Surround) to upmix to my speakers and I'm constantly getting problems with looping sounds e.g. the card will stop respoding and just play a loop of a tiny bit of sound!
Anybody getting the same?
Cheers
i get stuttering, happens after about 15mins. im using vista x64. its annoying and only happens in optical mode. going to buy a new soundcard soon
S/PDIF doesn't have the bandwidth for multichannel 24bit/192Khz, and DD only does up to 16bit/48KHz.
I'm not entirely sure what you're trying to do and with what settings but I think that may explain it?
i feel silly now lol. and i wondered why my DD kept freezing up at 24.192.
could coax output this? or could i use analogue?
S/PDIF is both, one 'interface' with two connections.
Use analogue if you want multichannel at higher resolutions and bit depths, it's only limited by what the card can do.
