I am planing to wall mount my TV and i would like to run the cables through the walls (both vertically and horizontally) as my AV system will be in the corner of the living room not directly beneath it.
Luckily i have Stud partition walls with metal style studs that have holes in for cables and water supply etc but the big issue is 'How do i feed the cables through'? Without ripping all the plasterboard off the walls or cutting 3 + access holes?
I did some wiring in another room to move some sockets and luckily i was able to wiggle the wires through but that was the stiff electrical kind. I doubt it'll be anywhere near as easy with speaker cables + HDMI etc? I am also unsure as to have openings and then use standard HDMI cables or to fit 'Multimedia plates' behind the TV and at exit point (but this seems like more opportunity for failure points)?
Ideas welcome?
Ideas welcome?
