No, alphabetical order
well that's much fairer.
that's my point. wouldn't it come down to away goals scored if gd is the same?
which if it wasn't obvious, the goal difference for both sides will always be 0 in a drawn 2 legged tie.
that's why i said from a table point of view?
Firstly, why would it matter in the context of this debate? We're trying to discuss whether it should be used, not whether it is used?
because if you'd looked at the post Tom84 made that i was responding to, you'd see that the 'debate' had gone down the route of % of defence and offence and that a home team should be expected to keep a clean sheet (in the exception of wigan)
there's little point in discussing should iit be used or not if you're not going to discuss such things, is there?
inter didn't keep a clean sheet at home. spurs did.
this is about as painful as watching Spurs trying to defend away...
EDIT Is this a lets all have ago at cm1179 thread?
Looking at the results in isolation, you can't argue that winning 3-0 is any better than winning 4-1 or vice versa.
err i think you'll find you can.
Seems to be a lot of butt hurt people around tonight because Tottenham went through.
