Bear said:I would have thought a megabusa would return more miles than that if looked after. They are 1.3 and technically a touring bike so would expect it to last a bit longer than a normal race bike engine, although I dont know anything about it really.
Northwind said:Busa engine's phenomenally strong, but car use puts different stresses on them from what they're built for. 'Specially if you blow them, and track them... which of course, you would
i'm not so sure.Dr Who said:Car doesnt really add too much stress, as we gear them far lower than you would on a bike...
gearing a 200 mph engine for 130 mph removes a lot of the stress you would think was added..
Dr Who said:gearing a 200 mph engine for 130 mph removes a lot of the stress you would think was added..
i'm not sure i follow you.Northwind said:Not higher, but different.
The_Dark_Side said:btw very nice spec in the OP.
i just can't like the Vortex "bulges" infront of the windscreen.
i just prefer the classic se7en look.
yeah mate I know the Vortex is aerodynamically superior to the classic seven...I just really don't like the result.Dr Who said:The bulges actually add wind deflection but I know what you are saying...
even so, surely regardless of gearing when you lift off the throttle the weight of the vehicle is acting upon the shafts in the gearbox and therefore the flywheel and crank assembly too?Dr Who said:The torsional forces on the crank arent as excessive as one might think due to the primary reduction in the engine...
The_Dark_Side said:i'm not sure i follow you.
different how?
and the fact the quote ends with "200kg" indicates that the weight of the vehicle is the deciding factor, namely that the weight of the vehicle will be riding through the gearbox shafts into the engine.Northwind said:Quote: me "Transmission stresses break more Busa engines than anything else, there's a reason that complete heads are so expensive- overrun one hard and you can bend all 8 exhaust valves. Much easier done on a low-geared kit car than a long-legged 200kg bike"
actually i did.Northwind said:Um... yes? Did you think I was disagreeing with you?
