Product has aids. Box might actually contain Pizza. You will be charged double and there are no refunds.
sorry if the question has been posted before
thank you for answering tho
might give it a miss then. well ill give them a call to double check the status if they still have it when im ready to buy a set of components in the very near future
What is it you're thinking of buying, if you don't mind me asking ?
If it's something like a motherboard it will probably just be damaged box/missing cables. I bought a B-Grade HDD over a year ago and it still works fine to this day, saved myself around £25 on that.
If the product doesn't work OcUK will refund it anyway so if it's a significant saving you may aswell go ahead with it.
to be fair does the site actually state what B Grade is? i looked last night and cudnt find the answer hence the post here. maybe i shud have looked harder?!the answer is in the OPto be fair does the site actually state what B Grade is? i looked last night and cudnt find the answer hence the post here. maybe i shud have looked harder?!
this is the item in question http://www.overclockers.co.uk/showproduct.php?prodid=BG-029-GW
to pair up a 4850 i bought just over a year ago but the one i have now is an HIS one with the big cooler.
a B Grade HD is something i wud not cahnce with! loss of data?!!
Why don't you just get this one? It's cheaper and brand new.
