**B Grade** OcUK ATI Radeon HD 3870 XT 512MB
what fps do you get in crysis with it? i just got a triplex 3870 and am quite dissapointed with it tbh, heres some runs from crysis using dx9-10 and 32-64 bit.
Run #1- DX9 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 27.81
NEXT BENCH RUN- 22/03/2008 20:44:52 - Vista 64
Run #1- DX9 1280x1024 AA=No AA, 64 bit test, Quality: High ~~ Overall Average FPS: 28.585
NEXT BENCH RUN- 22/03/2008 20:50:37 - Vista 64
Run #1- DX10 1280x1024 AA=No AA, 64 bit test, Quality: High ~~ Overall Average FPS: 21.595
NEXT BENCH RUN- 22/03/2008 21:05:34 - Vista 64
Run #1- DX10 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 23.085
NEXT BENCH RUN- 22/03/2008 21:23:08 - Vista 64
Run #1- DX9 1280x1024 AA=No AA, 32 bit test, Quality: Medium ~~ Overall Average FPS: 43.09
NEXT BENCH RUN- 22/03/2008 21:36:02 - Vista 64
Run #1- DX9 1400x960 AA=No AA, 64 bit test, Quality: Medium ~~ Overall Average FPS: 35.395
NEXT BENCH RUN- 22/03/2008 21:41:24 - Vista 64
Run #1- DX9 1400x960 AA=No AA, 64 bit test, Quality: High ~~ Last Average FPS: 27.06
NEXT BENCH RUN- 22/03/2008 22:13:15 - Vista 64
Run #1- DX10 1280x1024 AA=No AA, 32 bit test, Quality: VeryHigh ~~ Last Average FPS: 13.81
NEXT BENCH RUN- 22/03/2008 22:23:25 - Vista 64
Run #1- DX10 1280x1024 AA=No AA, 32 bit test, Quality: VeryHigh ~~ Last Average FPS: 13.85
on top of that dirt and cod4 wont run unless i drop the core from 775 to 740........
I would say thats prolly about right spookywillow if you are using the system in your sig. My guess is that CPU is holding back graphics maybe.
thats what i thought but my bro has a am2 5600 @ 2.8 which is only 100mhz faster than mine and cod4 runs smooth as anything on his with my card in without any driver errors, gonna go up again today with it now he's got more games to test it on.
Run #1- DX9 800x600 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 46.08 WinXP
Above is with the Triplex 3870, when I asked OcUK I was told they had the dual slot cooler in stock, but when it came in the post was the Triplex. Yes I ordered it the same day:(
Not a bad card though imo.
just tried it at those settings grumpy and with DX10 to compare and they are pretty awful, whats your cpu at? 3.4 ish?
Run #1- DX10 800x600 AA=No AA, 32 bit test, Quality: High ~~ Last Average FPS: 24.83
Run #1- DX9 800x600 AA=No AA, 32 bit test, Quality: High ~~ Last Average FPS: 35.39
Don't bother upgrading from an 8800GTS 320 to the x38x0 series. The ATI cards are faster, but not noticeably. The same applies for 8800GT > GTS 320.
I speak from experience.
I'd say something is either wrong, or your CPU is holding you back, or both.
This is my 3850pro @ stock, 1680x1050 medium: 47.395 fps
3850pro @ 904/1053, 1680x1050 medium: 56.42 fps
3850pro @ 904/1053, 1680x1050 HIGH: 28.485 fps
