PhilthyPhil said:Just look the ratings of the devices you are planning to connect, add them up and make sure its less than 780W![]()
PhilthyPhil said:Well a TV would be 100-200W depending on size, a fan maybe 100W if its a bigish one and a normal lightbuld is 60W. You should be able to run all that off a 780W generator, you might want something more substantial if you are planning 24/7 use though.
i know nothing said:....
Thanks for the insight. The thing is i honestly dont know how it would be used but am assuming on a daily basis. It is something meant as a gift.... Perhaps i will go ahead and get the b&q one at tell the end-user that it is something to be used intermitently.Ah ok, scrub what i just put in my edit above, there is no way that can be put in your luggage! Do think about fuel storage, those little ones will probably only run for a couple of hours anyway.ElRazur said:Also for the price it seems to be outputting plenty of wattage (780). I also need something small and compact to take on-board a flight when am going.
i know nothing said:Ah ok, scrub what i just put in my edit above, there is no way that can be put in your luggage! Do think about fuel storage, those little ones will probably only run for a couple of hours anyway.
i know nothing said:No problem, I have a whole range of gensets!
(email in trust)
if you connect a generator in your own house it will energise the cable in the street
Erm I don't think an airline will let you check that in.ElRazur said:I plan to check it in not put it in my luggage lol. Also, as per the bigger work horse one, i will be having a chat to you in the near future if you dont mind.![]()
big_white_dog84 said:Out of interest, how does the 780W connect to your house supply?
When I'm out fixing faults on the electricity network it is a real pain that people might have their own generators cause it adds loads of work to the fault repair. This is because if you connect a generator in your own house it will energise the cable in the street, and ultimately transform back up to 11kV onto the high voltage network. This means we need to adjust out working techniques to keep ourselves safe.
ElRazur said:It says on the instruction manual that the petrol has to be mixed at a certain ratio 50:1 to be precise....Anyone know what is this mix that i have to add to the petrol? Thanks.
