Now changing the subject to something hardware related.
All the fans mounted in BackDraft are PWM, the idea is to have them run off a single control unit that reacts autonomously to the temp changes of the CPU; namely when gaming overclocked and benching they run up and down accordingly.
The obvious candidate would be an Aquaero, this was my initial choice however I know the software still isn't the best and further they require temperature probes to be located at key points; so instead I've decided to try out one of these instead -
It's a Swiftech 8 Way PWM Splitter
Product Description
The function of this device is to connect up to 8 PWM devices (fans and/or pumps) to a single PWM fan conector on the motherboard, thus enabling speed-control of all connected PWM devices concurrently.
Basically I'll be using the CPU header of the motherboard as the Master and in conjunction with a profile created in Gigabyte Easy Tune 6 have a fully antonymous method of control.
Simple but effective
The downside being I've had to order it direct from The States as no one in the UK yet stocks them
Product Description
