Backlight bleed problem, is this normal?
26 Mar 2007
Nottinghamshire
So the wife bought me a 27" Samsung monitor with a PLS panel for Xmas and something just doesn't look right to me. The screen is not uni-formally lit even in bright light so I did a back light test and this is the result.
backlighttest_zps525b75a5.jpg~original
Where do I stand on getting this replaced or am I stuffed?
right corner looks very bad, i would return it.
That's the thing, she bought it for me in the last week of November and it's been sat until xmas day unopened so I can't just return it, it would need to have a fault and I'm unsure if this could be classed as one.
Argos are usually easy to return to, just say the frame is misaligned and the light is showing through, if you say lightbleed they might just stand there with a derpy look on their faces.
