Is backlight bleed common? Do all TFT's suffer from this? I just bought a Viewsonic 17'' TFT and it is noticeable on the lower edge. Not sure if i should go back to CRT!
i wouldn't describe that as backlight bleed really, more uneveness in panel uniformity. This kind of thing is quite common on a lot of screens really, you should find some models are better though, but you can certainly see some much worse cases than that
