Hey guys,
I'm thinking about making a second build on a fairly tight budget as a backup build/overclocking/testing out new MS operating system, like Windows 7 using Intel.
I've had a look at http://www.overclockers.co.uk/showproduct.php?prodid=BU-161-OK&groupid=701&catid=339&subcat=1333 this bundle to start off with, but I wanted some input from you guys. Are these parts any good?
I've had some nasty experiences with RAM incompatibility in the past so that's why I'm looking at bundles, but can anyone recommend me some parts, either quad or dual core setups not exceeding 200 quid? Even setups you guys may have
Cheers
Cheers
