Backup Solutions
18 Oct 2002
Nordschleife
I currently need to invest in a upgraded backup solution and wondering what are your thoughts on:
  • Acronis True Image 9.1 Enterprise Server
  • VERITAS 10d/symantec Backup Exec 10d
Both products will be backing up 640GB of server space and upto 40/50 PCs locally and remotely onto a central DAS server.
We used veritas 9 to backup Exchange mailboxs and SQL data but want to extend this into a carbon copy of OS/SQL/Mail etc.
I need it to be able to backup servers while still online/in use.
To backup remote users via ADSL/Cable connections.
What are the differences between the BE products?
Are you planning to backup dara across a load of local pc's.
Veritas is a very proven product for backig up data. I wouldn't use anything else.
Have you thought about using Veritas Netbackup? It is a hell of a lot better than Backup Exec when it comes to managing multiple backup policies across multiple sites.
It is a bit more expensive though.
For one of our clients I deployed a 5TB dedicated server in london to backup all there work. A smaller scale thing might be suitable for your remote connections.
What kind of connectivity do you have at the office?
