- 18 May 2010
Hi,
I have Windows 8.1 and a dedicated internal backup drive, I've been using Windows File History and I really don't like it, it works in the opposite way that I would want IE you have to exclude locations rather than just add the one or two locations that I want backed up.
Is there any way or any software that I can use to backup to an internal drive that I can point to the one or two folders I want backing up that will copy and changes made to those folders automatically?
Thanks
Thanks
