Bad problem HELP!!! Nothing displays on screen ect!
maybe just disconnect everything you have and rebuild it back up with just the processor, psu, motherboard and video card then see what happens. Ive seen anything cause things like this youd be suprised, even a usb modem can cause a no post
Sound like PSU or motherboard, don't know if you have a friend with a similar system that you could check your components with.
No shorting out on the motherboard? Perhaps if you build it up outside the case. It sounds as thoguh it wouldnt make any difference, but it does sometimes.
