Wow thanks for all the info guys I really appreciate all the help, hope you can tolerate my questions for a little while longer before I make my choice
The NEC looks very impressive, the opticlear is very nifty, I love the glass-glossy screen on my laptop so a screen like that for my computer would be perfect. But the NEC doesn't come with HDCP and it's very expensive.
Meanwhile the Dell 2007WFP looks almost as good as the NEC, it's almost £100 less and it comes with HDCP but...it doesn't have a glass screen like the opticlear? you don't have a review of the 2007WFP on your site do you baddass?
EDIT:
About this whole HDCP thing, I know what it is, but I'm really not sure if I need it on my monitor. The reason I've specified HDCP is because a friend of mine suggested that a HDCP compliant monitor is the way to go but I'm not exactly sure why, what will I get out of it? Surely it only concerns High Definition DVD playback from a bluray or HDDVD player?
Do I need the HDCP compliant in order to use my X360 with the monitor at 720p?
EDIT2: I've done some more reading about HD support and found that HDMI is the port that allows the HD compliant connection between HDDVD/bluray/Xbox360 and the monitor, but do HDMI compliant monitors always have HDCP too?
