- 12 Sep 2011
Hi. I've got an issue with my home internet connection. I have ethernet connections running from 4 ports on the router to different rooms in the house and all being used for pc's/consoles etc.
Everything works fine without any issues under normal usage however, as soon as my son starts to download a game onto his console or pc, the port he is using automatically hogs all of the bandwidth and no one else in the house can use the internet.
This is the only port/room that does this and it happens whether he's downloading on his console or pc.
My router does not have any QoS service on it. Can anyone advise why this might be happening and suggest if there is a work around without the need to buy a router with QoS?
Thank you.
Thank you.
