bandwidth monitoring prog
26 Oct 2002
Corby Glenn
hi guys.
i seem to be getting a lot of lag gaming atm.
is there a prog that will monitor my connection so i view it later to make sure it is my connection.
regards
jobe
Depends whether you've got a router or something between you and the internet that'll let you monitor what's going on. If you've only got one machine, there's something like DUMeter or NetMeter that'll install on your machine.
DU Meter is good :) I'm using atm and haven’t found any faults currently in the trial period but I will defiantly buy a key once the 30 days are up.
It has a nice totals report system as well;
i was looking for something that outputted into a line chart if thats the correct term.
whats happening is i can play ok for 20 to 30 secs then get a connection error symbol on screen for about 5 secs. everything jiggles around (technical term) and basically i'm dead in the water for that time and figure i must be lagging. 'in game' my ping goes to 999.
does anyone think it could be something else?
