Barracuda 200gb sata making nasty noises
19 Oct 2002
The land of Cows n Grass!
Im having problems with a Seagate drive that I bought from the MM. Everytime I format the drive it emits a really nasty "chink" and "Rattle" sound, none of my other seagates do this so it alarmed me big time!
Speedfan says the smart thing is ok so I downloaded the seagate windows tools and that passes the drive fine (I only did a quick test tho)
Im thinking about rma'ing it but im worried if this problem was caused by the postey throwing it about would they just void it and return it back?... Should I just rma it anyway and see what happens?
Run an advanced test, ASAP.
It could well be that you've fired it up, and used it aggresively from the word go. Sometimes I find it's best to give harddrives a good 5 minutes or so from cold, so they can warm up.
