Barracuda 7200.7 Hd incredibly slow
10 Apr 2006
Edinburgh
Was fixing a pc for pal and it has a 160gb Barracuda 7200.7 in it.I deleted ide channels in device manager as i thought usual prob stuck in pio but it didn`t do anything.Tried different cable/channel no luck either.Swapped in an old 20gb drive and that works fine.
Looks like something physically wrong inside,it passed some seagate tools tests albeit slowly.I haven`t tested it in another pc yet to rule out faulty mobo just wondering if i could reflash the firmware or something or is bin best for it.
Unfortunately its oem and out of warranty.
Cheers
Have you checked in Device Manager to see what mode the drive is running in? Check the BIOS too, sometimes there's a setting in there which will limit the controller mode but I've no idea why that would change to a lower mode.
Dma channel shows dma 5 but even an underclocked p166 would beat this celeron based 2.6ghz one for performance :p .Drives just usually error/die its just weird.Will try it on my one later.
After a lot of multi-slacking i finally got around to trying in another pc.
It worked fine up until i wanted to try defragging the main drive-then it wasn`t having it,utter crawl even after cancelling defrag and reboot.
I think i just witnessed the ol `i`ll work for 2 mins before i die` routine,ah well bin ye go.
