Basic bash shell programming question
18 May 2010
London
Trying to improve my skills and currently undertaking a bit of self taught bash programming.
I'm working on a little script that along with a few other things will calculate if the year is a leap year if the month is Feb.
I found the following script online and I'm trying to incorporate it in to my script.
However I cannot understand the values of y and year.
echo "Enter Year:" # So for example if 2016 is entered
read y This would make the value of y 2016
year=$y Here I understand it to mean the variable y = the variable year
y=$(( $y % 4 )) This is where I start getting confused. Why are we defining what the variable y equals again?
if [ $y -eq 0 ]
then
echo "$year is Leap Year!"
else
echo "$year is not a Leap Year!"
fi
I understand what the gist of it is. It basically tests to see if the year is equally divisible by 4 if it is it is leap year, if it isn't it is not a leap year.
Basically after the "read y" the "year=$y" line is just so that when reporting the result "$year" is equal to what you entered, after overriding y with the calculation.
It's badly written really by overwriting y, would be nicer if instead you had something like "leapyear=$(( $y % 4 ))" and then checked that against 0, preserving y to be echo'd in the result.
SKILL is right, that code is not great ... personally I'd probably do something like the following (not tested)
Code:
echo "Enter Year: "; read year
leap_test=$(( $year % 4 ))
if [ $leap_test -eq 0 ]; then
else
fi
(which is basically what SKILL said). There are probably more elegant ways of doing it though.
