Whats the best way to connect a normal cable box to a TFT (Dell 2407WFP)? THe box only seems to have a scart out. Any cables available i could use for this?
well i need to convert the scart to somethuing like s-video + L & R audio phono's, just not sure what route to take and was wondering what everyone else does for this problem. THe cable box i've got from virgin is a bit naf, i thought it would have more outputs than just a scart.
If the Dell panel has an SVGA input then it's easy, you can get a lead from SCART to SVGA plus 2 phono's. Try that High St. retailer that sounds like it's from Hi de Hi.
