i HATED stuff like this.. ive never used anything of the sort in life so far lol
StevenG
erm still not understanding exaxtly how it is done.
(ab)3b
b
3b^2a
b
b(3ba)
b
I'm assuming the . means multiply.
(a.b) 3b
b
Should actually be written:
3b(ab)
b
Anyway:
3b(ab) is simply 3 * b * a * b
3 * b * a * b is 3ab^2 (^2 means squared. In this case b^2 means b x b)
3ab^2 / b just means you need to remove a b. 3 * a * b * b / b is:
3 * a * b = 3ab
How is this difficult? Just cancel the b on the top with the b on the bottom, then stick the 3 in front of the brackets.
Why do people insist upon using ^2 instead of ²?
It makes maths posts like these so difficult to decypher some times
ALT+0178 people!
3b^2a
b
