Basic Mechanics 101 - Anti Roll Bar Drop Links
special note: not so simple on most french cars, those internal allen key nut jobbies are absolute ****s to get off! you just go crazy with a grinder on these n hope for the best :D
I usually just cover in wd40 and wind a new nut on and off the thread a couple of times to clean it up. The nut on it should then come off quite easily. If still stuck and you aren't replacing the droplink, a jack under the anti roll bar should put enough pressure on the top thread for the bolt to undo.
Never had to grind off a droplink and done it probably 50 times on 306/106/xsara/saxos even on ones that hadn't been touched in ten years.
Nice one Lopez, it's good to see posters in here taking the time to educate others on basic mechanics and stuff. :)
Nice write up
I gotta do the ARB bushes for monday. I brought some superflex as they last 3 times longer they say and they only cost £4 more than the standards :D
