11 Jan 2015 at 11:34 #1 Aeleys Aeleys Soldato Joined 25 Aug 2010 Posts 5,216 I'm a massive noob, looked online but google skills are weak I guess. I just want a spreadsheet that can calculate my hours worked, including unpaid breaks Any help or suggestions?
11 Jan 2015 at 13:00 #2 DaleTheWhale DaleTheWhale Soldato Joined 17 Aug 2012 Posts 6,593 Location Tamworth, UK Surely this is as simple as entering your daily hours and then having a total at the end to sum that week?
11 Jan 2015 at 13:23 #3 izzop izzop Associate Joined 7 Jul 2009 Posts 2,399 Location Wiltshire Here you go..... Figure out the number of hours worked in a day Or if you want to record your breaks.... Figure out hours worked minus lunchtime Regards
12 Jan 2015 at 08:54 #4 Frozennova Frozennova Man of Honour Joined 13 Nov 2009 Posts 11,666 Location Northampton Here's my simple one I use https://cloud.baucutt.me/public.php?service=files&t=8c9a062cc170d16bc0fc5d9ce4608cf9 Doesn't calculate weekly hours only for the year as I'm contracted 2087 hours a year rather than 40 hours a week
12 Jan 2015 at 09:29 #5 Deleted member 77746 Deleted member 77746 Permabanned Joined 9 Aug 2008 Posts 35,711 Aeleys said: I'm a massive noob, looked online but google skills are weak I guess. I just want a spreadsheet that can calculate my hours worked, including unpaid breaks Any help or suggestions? Click to expand... Google: " spreadsheet hours worked "
3 Feb 2015 at 18:47 #6 Aeleys Aeleys Soldato OP Joined 25 Aug 2010 Posts 5,216 mrbell1984 said: Google: " spreadsheet hours worked " Click to expand... I have many many times, none of them are worth anything. Plus all are for Americans it seems. I'll have a look at the ones posted above thanks.
