I noticed some moisture dripping from the vent into the bath so I've just been up into the loft to have a gander. We had it fitted in 2009 and the ducting is a bit minging to say the least. The fan is a Manrose 25652 which came up as a showerlite one when I searched but we dont have the light just a beige coloured facia.
The ducting is just attached to the facia (don't know what the technical term is for this!) in the loft to the fan and then from the other fan end to the plastic ducting going up to the roof where it expels. It's just the basic white plastic ducting so should I just replace it with the same (think it's 4")? The fan is also pretty mucky so what's the best way to clean that? Same way as you would a PC fan?
I'll take a crawl up there again later and take some pics which I hope will explain better!
