Battery Condition: Replace Now
Commissario
23 Nov 2004
Herts
Just what I need...
I think my MacBook has just run out of warranty too. I presume the norm is to source a new battery out of my own pocket?
Purchased one in the Brighton store this weekend, they honoured the higher education store too which was a result.
How do you go about replacing the battery in the newer mbp's? Since its not easily removeable i guess most people would have to send it to apple?
After a discussion on this, after I said I was experienced building PCs etc, the guy in the Apple store said that 'technically' they're not user replaceable. However, he showed me what to unscrew on the bottom and said 'It's easy; just do it yourself and play dumb if asked'. He also advised that if I want to upgrade to SSD or add extra RAM, that I should do so - but to remember to switch it back to OEM parts if I need to get a repair so that Apple won't invalidate the warranty. :p
I had thought that the latest MacBooks were designed with the RAM and HDD to be user-upgradeable and that this wouldn't invalidate the warranty. Perhaps I'm wrong. :(
It's not a case of invalidating the warranty, it's that Apple won't support the machine with non-Apple supplied parts in it. Seems reasonable.
Same applies to all the big PC makers. Keep the spare bits to one side and put them back in if it develops an issue.
Makes sense. Cheers.
