Hello!
MINI Cooper S R56 '57 plate
Yesterday afternoon while driving the car the following message appeared on the screen:
The charging fault also appeared again after 5 minutes of driving. The battery has not been changed during my ownership of the car (2.5 years) and I don't remember seeing any evidence in the service history of a battery change. I understand a new battery will have to be programmed to the car but Berry Heathrow want £210 + VAT!!! I'm slightly worried it's more than just the battery considering the diagnostic machine said it was ok and the fault says charging fault rather than battery fault. Berry Heathrow wanted a further £99 but just for diagnostics!
Any suggestions?
The car appeared to turn off the fan etc but drove normally. Today I took the car to Halfords and their battery checker showed it was "ok" but needed a recharge. I was a bit dubious, so attempted to take it to "kwik" fit but they left me waiting for over 30 minutes before I gave up. When I turned the car on to drive home the time and date had disappeared and the following message appeared:Charging Fault said:Battery no longer being charged. Switch off electrical consumers that are not required! Have the problem checked by your local MINI dealership
And:Time and date said:Battery was disconnected. Time and date are no longer correct...
Vehicle Battery said:Increased battery discharge while stationary. Electrical consumers may have been switched off. Reset date and time if necessary
Any suggestions?
