Does your car have stop start? If so that could indicate that the wrong battery is fitted as I would expect an AGM battery to be fitted to a car with stop start. Did they tell you what battery is supposed to be fitted as there are a few choices that can be selected via coding?
No stop/start, it's an early R56 model and I have a blank switch where the stop/start button should be.
The garage have just got back with a quote:
Part: 61216924021 - Original BMW AGM Battery (£132)
The alternator is either of these two models, they can't tell until they've removed it apparently:
Part: 61216924021 - Alternator 150a/h (£560.98)
Part: 12317619254 - Alternator 120a/h (£120.95)
Ouch!
Garage said:The current battery fitted to the vehicle is of a standard 70a/h lead acid type and not the 70a/h AGM type technology, this is incorrect for the specification and configuration setup of the vehicle.
This is what the garage have said.
A copy of the diagnostics they just sent me: http://i63.tinypic.com/29pc5kz.jpg
