- 5 Jul 2003
- Cheshire
Amp34 said:A small handheld fan (9v) says it uses 200mA and 200mW.
Those figures cant be right.
If you have a current draw of 200mA at 9volts then the power consumption is as follows (roughly).
P=V.I = 9x200x10-3 = 1.8 watts
or if you work off 9 volts and 200mW
then the current would be
I=P/V = 200x10-3/9 = 22mA
Fog
Its a single unit with all the things built into a sortof case, It must have some resistors etc on the IC unless the manual is wrong.
