Bayonetta help!
I am thinking of picking this up later but the PS3 versions seems to have got some mixed reviews. Does anyone know if they patched the issues, or if they are they really that much of an problem if one hasn't played the 360 version?
They've released a really well received patch that improved the performance significantly. Even before then people found the game perfectly enjoyable on the PS3.
There were no performance issuses on release on the PS3, the only thing that I noticed was different after patching was that the game could now be installed on the HDD so the loading times were shorter.
So, still getting stone statues, but don't care!
Question, do you keep your currency (The rings that looks like they are from Sonic) and items on your second play through? Or do you start out from scratch.
ags
You keep everything - the game would be next to impossible otherwise. I 'farmed' certain levels over and over while practising. Keep playing and you'll have more than enough cash.
I am fed up with the game and going to sell it now!
I am afraid that I will have to follow suit. I was enjoying it up until the boss of chapter two but it's completely bugged. Firstly I had to replay the whole level for some reason and now I am stuck on the very difficult part where the game tells you to press square.... no matter how fast I mash the square button I die.
Yet all reviews under the sun said differently most off them in fact said there were clear differences in performance between versions and recommended the 360 version over the ps. This is not bashing just what was said and I'm glad they patched it up.
Press square to dodge or square to stack up damage?
Neither. It's a button prompt. For some reason if you mash the button it doesn't work. Also I don't get why if you quit on the boss that you have to redo the whole level, but if you quit before the boss you can start at a check-point!
No, all the reviews didnt, two reviews did from what I can remember.
The game had no issuses what so ever other than the loading times.
