Be* being slow!
I have just made the switch from Sky to Bethere....and I sync at over 15mbps but I was having major problems with the DNS servers....just timeouts and very slow browsing...basically unusable.
I just logged into my router and set the DNS servers as the OpenDNS ones and now it's lightning fast!! wee!!
**edit** I just grabbed a torrent downloading at 1.4mb/sec! Very pleased with this service!
^I would just set them to the opendns servers for reliability....I went to the bethere forums and it seems as if their dns servers have ALWAYS been sketchy...so I wouldn't count on them getting better anytime soon.
did some digging around and turns out our outage in the evening was a DoS attack on core network firewalls.
shouldn't happen again :)
Nothing there;
when I set mine up I didnt get these options..the only one I had was for static IP 4 data ports?
even my instructions told me to set it to static with 3 data ports (the 4th reserved for something else) but I simply didnt have that option in the drop down
Bump!
Does anyone know how to change to the OpenDNS servers using the BE-Box? I can't find an option anywhere that allows me to manually set the DNS server details?
theres a thread on the be forums (need to be logged in to view it) about general network congestion on the be network and how there was supposed to be an upgrade on the 21st.
my exchange was on the list that was meant to have benefitted but as of yesterday afternoon (23rd), downloading was going at 250k/sec instead of the 1.2mb/sec i usually can get. powered the router off/on but to no avail, still the same speeds.
you have to do it via telnet mate
dns server route flush
then
dns server route add dns=208.67.222.222 metric=1 intf=RoutedEthoA
dns server route add dns=208.67.220.220 metric=1 intf=RoutedEthoA
Bump!
Taken from the OpenDNS forums:
First, you will need to access the router via Telnet. To do so, please follow these instructions carfully.
First, you need a command prompt.
To do this go, START > RUN... > Type "cmd" (without the quotes).
Once at the cmd prompt, type :> telnet 192.168.1.254
Enter your user name: Administrator (by default, note capital A)
Enter you Password: (blank by default)
A prompt like the one below should appear.
_{Administrator}=>
Your in.
To exit, simply type "exit" (without quotes)
Changing the DNS IP's.
Setting Different DNS Server Addresses within the Router (if Your DNS servers are too slow, and you would rather not reconfigure each of your PCs)
Flushing DNS Servers assigned by DHCP (and any you have previously added manually):-
:dns server route flush
Setting Primary & Secondary DNS servers:-
:dns server route add dns=[Insert Primary DNS Server Address here] metric=1 intf=RoutedEthoA
:dns server route add dns=[Insert Secondary DNS Server Address here] metric=1 intf=RoutedEthoA
When the router contacts DHCP again, the DNS addresses allocated will be below those you have added above (so your choice of DNS will be used first - if both your DNS servers are offline, then it should attempt to use the Be* DNS).
To view the DNS servers:-
:dns server route list
I use OpenDNS:
Primary: 208.67.222.222
Secondary: 208.67.220.220
E.G. With the above command line I would enter at the telnet prompt:
THEN:
:dns server route add dns=208.67.222.222 metric=1 intf=RoutedEthoA
AND:
:dns server route add dns=208.67.220.220 metric=1 intf=RoutedEthoA
THEN:
:dns server route list (to make sure the changes have taken)
THEN:
"saveall" (If the router is powered off for what ever reason, this cmd will retain the DNS IP's)
typing "exit" will exit you from telnet.
Thanks both Si MPS & Angler,
The second post was a bit more detailed and was what I needed to get the job done although I got confused by the THEN: AND: THEN: bit! :o
Heres an edited version for sporks like me! :D
Assuming you have already logged into your router via TELNET
[press enter]
[press enter]
[press enter]
[press enter]
saveall
[press enter]
exit
[press enter]
All working nicely now thanks again! :)
I have my broadband with O2 which is also part of Be and had an email saying that they are doing improvement works this weekend in Wiltshire so to expect possible disruptions. I couldn't get on first thing this morning but after leaving the router off and reconnecting its running really fast with no stalling or refused loading on certain pages. Maybe this is the start of the improvements for Be?
Ditto service had been excellent for 3 weeks then this weekend unable to check email, join servers in games, use VOIP, surf the net etc.
The traceroutes were dying 2 hops out on betheres network :( i hope it gets sorted quickly
Anyone reckon my issues are my equipment related? Pings fine, 30ms etc., browsing takes forever! even on opendns.
Cant connect to any online games servers or check emails it always times out.
Microsoft Windows [Version 5.2.3790]
(C) Copyright 1985-2003 Microsoft Corp.
C:\Documents and Settings\Administrator>tracert www.bbc.co.uk
Tracing route to www.bbc.net.uk [212.58.251.202]
over a maximum of 30 hops:
1 1 ms <1 ms 3 ms 192.168.1.2
2 * * * Request timed out.
3 * 22 ms * 83.245.126.93
4 * * 22 ms 212.58.238.129
5 * * * Request timed out.
6 23 ms 21 ms 21 ms www2.telhc.bbc.co.uk [212.58.251.202]
Trace complete.
Having moved from crappy pipex, was supposed to be on 8mb down and 1mb...id be lucky to get anywhere close to that...been with Be since beginning of Feb now and i swear i havent looked back...i currently synch at 19mb down and 2mb up and honest to god it very very quick.
Saying that though, my exchange was down for a few hrs sat night due to some upgrades taking place but in the morning it was fine and super quick. I havent noticed any drop outs or slowness since i moved from Pipex. I easily get about 1.7 mb down on torrents whereas before id be lucky to get 100kb/sec:p.
Cant fault Be at all, mega impressed and happy with them...long may it continue:).
i have something really odd. basically websites take forever to load, but i download at superfast speeds. I am guessing their dns is well dodgy, so im changing it hopefully it will fix it...
